How should I prime these ceilings
Old 02-08-09, 02:23 PM
C
Received 1 Upvote on 1 Post
I have a small house with drop-in tile ceilings, 2'x2' tiles. Over the years it's been smoked in and I need to repaint now.
So I am wondering what would be the best product to prime with before applying ceiling paint.
Your thoughts? Thanks.
Old 02-09-09, 03:11 AM
Received 759 Upvotes on 664 Posts
You should use a solvent based primer. There are some latex primer/sealers but they don't always adequately seal the stains to keep them from bleeding thru the finish coat of paint.
Old 02-09-09, 08:11 AM
For smoke, you may have to seal with a Shellac-based primer like Zinsser BIN. An oil-base may work, and it is less nasty to apply. (BIN more or less requires a cartridge respirator, while you could probably get away with a LOT of ventilation if you use an oil-base primer.)
Don't waste time with a water-base; it won't work for smoke.
SirWired
Old 02-09-09, 08:55 AM
F
Replace them?!
This is one of those situations that MAY warrant replacing them if they're just the lightweight drop-in ceiling tiles.
I haven't priced any for a while, but it seems easier than doing all the paint-prep., primer-fumes, dry-times......
In two hours, you could do LOTS of tiles, with no smell!
Faron
Old 02-10-09, 04:38 PM
C
Good point about replacing them
but I still have the problem of the stained grid, thus would need to prime and paint anyway.
