Paint shades & types
Old 02-18-00, 07:29 AM
Guest
Question
Ok...I asked this before....forgive me but
I need to be clear! I want to paint both
the walls in the hallway and den the same
color, Country White, and also the trim
the same Country White....Should I use
semigloss on the trim, and satin and eggshell
on the walls....(the den is paneled...)
Once before someone mentioned that even
though it would be the same color, the sheen
would make them look a bit different....
Thanks so much from this beginner!!!!!!!
dsue@ccnmail.com
Old 02-21-00, 05:42 AM
B
Post
I would use either eggshell or satin on the walls and a latex enamel on the trim. The enamel is a little harder and will wear better.
