Solvents for Paint, Varnish, Lacquer
Old 03-07-00, 12:59 AM
Guest
Question
I would like to know what solvent is used for what painting job. There are a few solvents on the market e.g. Turpentine, thinner, methylated spirit, white spirit, kerosine, etc. that I am afraid that I might use the wrong solvent for thinning. I am aware that latex paint uses water for thinning. What I am specifically interested is the solvent for lacquer, shellac, varnish. What is the difference between methylated spirit and white spirit?
Old 03-07-00, 06:24 PM
Guest
Personally, I think you're reading a very old book (which should either thrown out or you should learn the conversion names), you're reading a book published in the U.K. or Europe (in which case the same advice applies), or it some sort of homework assignement.
In todays World of painting this information rarely applies, but, since this is a Do It Yourself Web Site, here is a list of the more common solvents, after which, you are on your own.
MEK "Methel Ethel Ketone"
(AKA "Synthetic Reducer" - may be combine with other solvents)
A high strength solvent.
Use:
A specialty solvent to be use only where directed and as directed.
Generally for epoxies, fiberglass resins, and specialty coatings.
Cleaning:
Use to clean painting tools after applying any type of coating.
Will soften hardened coatings and most synthetic materials including synthetic brushes.
WARNINGs:
Flammable. Read cautions on the label carefully.
Do not use a confined area without proper ventilation.
Toxic, with cumlative affects. (Death, Brain, and Nervious System disorders).
Will attack some synthetic brushes.
!! Do not use with standard spray equipment.
!! Spray applications: wear a fully self-contained positive pressure suit.
Toluol - Toluene
A high strenght solvent.
Use:
A specialty solvent. Use as directed to thin many lacquers, rust inhibitive, rubberized, marine and other specialty coatings.
!! Not for use with most oil based paints, varnishes, stains, shellac or polyurethanes.
Cleaning:
Use to clean painting tools. All coatings except shellac.
WARNINGs:
!! Vapors linger at floor level. Do not use a confined area without proper ventilation as the possibly of an explosion from an ingnition source is real.
!! Nitified Toluene is the explosive "TNT".
Toluol is a octane booster for gasoline. Some Hot Roders add it to gasoline for performace reasons.
Xylol - Xylene
Use:
Cleaning:
WARNINGs:
Acetone
A high strength fast evaporating solvent.
Use:
Generally for epoxies, fiberglass resins and specialty coatings.
Cleaning:
WARNINGs:
Toxic. (Death, Brain, and Nervious System disorders).
Paint Thinner
A general purpose solvent.
Use:
Most oil based paints, varnishes, stains, polyurethanes and wiping oil finishes.
Increases flow, reduces brush drag, and extends drying time slightly.
!! Do not use with shellac, lacquers or latex paints.
Cleaning:
A mild solvent. Clean painting tools while coating is still wet.
Will not soften dry paint films well.
WARNINGs:
Do not use a confined area without adequaret ventilation.
Gum Turpentine
Use:
Thinning most oil based paints, varnishes, stains, polyurethanes and wiping oil finishes.
Increases flow, reduces brush drag, and does not extend drying time noticeably.
Its evaporation rate is the same as many paints.
!! Do Not use with shellac, lacquers, and latex paints.
Cleaning:
Gum Turpentine leaves a slight rosin residue.
WARNINGs:
Mineral Turpentine
(AKA Mineral Spirits)
Use:
Increases flow, reduces brush drag, extends drying time slightly.
Cleaning:
WARNINGs:
Kerosene
Use:
The purest lowest sulphur grade (1-K) may be used in place of Paint Thinner but it increases drying time.
Kerosene is mainly a fuel.
Cleaning:
Clean painting tools while coating is still wet (oil based paints, stains, varnishes or polyurethanes).
WARNINGs:
Naptha - VM&P Naptha "varnish maker's and painter's solvent".
(AKA White Spirits)
VM&P "grade" an excellent thinner for most oil based paints, stains, varnishes and polyurethanes.
Cleaning:
VM&P is one of the best petro-chemical spot cleaners.
Removes dirt, grease, tar spots, etc. It may soften synthetic plastics, fabrics, rubber or the dyes in printed fabric.
WARNINGs:
Toxic. (Brain, and Nervious System disorders).
Stoddard Solvent - similar to Naptha
(AKA White Spirits - in some places)
Stoddard solvent is a colorless, flammable liquid. It smells and tastes like kerosene.
It is a petroleum mixture. It is also known as dry cleaning safety solvent, petroleum solvent, and varnoline; its registered trade names are "Texsolve S" and "Varsol 1".
It is a chemical mixture that is similar to white spirits.
Use:
Stoddard solvent is used as a paint thinner, in some types of photocopier toners, printing inks, adhesives, and as a dry cleaning solvent.
Cleaning:
General cleaner and degreaser.
WARNINGs:
Lacquer Thinner
Use:
Nitrocellulose based wood finishing lacquers and some one and two part epoxies.
!! Do not use with acrylic lacquers, automotive lacquers, varnishes, shellac, polyurethanes or paints.
!! Solvents for acrylic lacquers and automotive lacquers are known as "Reducers".
Cleaning:
Clean painting tools after painting.
Will soften most types of coatings with prolonged immersion.
Cutting grease on metal parts (prolonged exposure can attack seals and gaskets).
WARNINGs:
Guest
