Painting
I have read that it is possible to paint over oil paint with LATEX paint without priming first and you ONLY have to sand the shiny surface first. I am trying to repaint my woodwork and would like to paint it with LATEX paint(it is painted with oil paint now)
Latex paints are much better than even 5 years ago. Normally you wouldn't need to prime. You are correct about the 'shine', though. That shine could keep the paint from creating a good bond.
If the old paint has been there for a number of years (8-10 or so), then you may not need to sand. If the gloss (shine) is high, then do sand.
How old is this oil paint? If it's old enough to contain lead, sanding is exactly what you DON'T want to do. Use TSP, then put on an alkyd primer, then your latex color coat.
One other option you have is the newest type of paint.Devoe and Sherwin Williams among others have a waterborne enamel that is applied to any surface inside or out ending the age old problem of "what kind of paint do I have to use over my existing paint".Be advised that this enamel does not hold back bleeders such as lipstick,pine sap,cigarette smoke or waterstains.A normal routine of kilz or some similar stain killer is in order.Believe it or not this paint cleans up with water.Try the waterborne,you will love it!!!
mikejmerritt1@yahoo.com
