removing paint on windows without using a razor blade
Old 05-17-00, 01:26 PM
Guest
Question
I painted our back door with exterior paint, but did not put masking tape around the window. and would not have been able to paint the edges of the window if i had. Now I have heard the only way to remove the dark green paint is to use a razor blade and scrape away. any more ideas?
Old 05-18-00, 08:05 PM
Guest
Post
A well run out rag with lacquer thinner as the solvent is one way.
Old 05-19-00, 05:27 AM
Guest
Post
Why not use the razor blade? It's quick and easy. If you use lacquer thinner as a solvent, what happens when you drip some of that solvent on the good paint? Save yourself a headache...use a razor blade.
Old 05-19-00, 05:46 AM
Guest
Talking
quote:<HR>Originally posted by tearfilled:
I painted our back door with exterior paint, but did not put masking tape around the window. and would not have been able to paint the edges of the window if i had. Now I have heard the only way to remove the dark green paint is to use a razor blade and scrape away. any more ideas?<HR>
I tried the razor blade afterall and it worked better than I had expected. The door looks great. Thanks!
