Painting Cork??
Old 08-06-00, 08:05 AM
Guest
Question
I have recently moved into a home that has cork and mirrors on one wall of the living room. I imagine that this was done to make the room look larger. I don't want to remove it at this time but want to lighten the cork. Is it possible to prime and paint the cork without the dark brown bleeding through? and if so what kind of primer and paint should be used.
Thanks,
Debbie
Old 08-06-00, 08:07 PM
mikejmerritt
Post
Hi dbrhadms,If you use an oil based primer you can use any top coat you choose.
