Paint Sprayer oil
Old 03-21-09, 02:37 PM
Question Paint Sprayer oil
Could someone help me? I just bought a titan paint sprayer but their was no oil for start up.Should I use w30 for that or somerting different ? Thanks
Old 03-21-09, 06:55 PM
P
Temporarily Suspended
I would ask someone where it was bought or call the manufacturer.
Old 03-22-09, 05:16 AM
B
go to a paint store and get either separating oil from Spraytech or Throat Seal from Graco. either will work. NOT motor oil. (Altough if you repack it, you will use light weight oil)
Old 03-22-09, 05:25 AM
Received 398 Votes on 354 Posts
I've always used throat seal.
BC - I have 2 titan 660s that have been repacked numerous times and I used to work for an outfit that had several graco 433, 533 and 733s that had the packings replaced periodically and throat seal was always used. Never heard of using light weight oil
Old 03-22-09, 05:45 AM
F
the manual should tell you what to use. throat seal oil if it's a piston pump and synthetic motor oil if it a diaphragm pump.
Old 03-23-09, 03:47 AM
B
we found the light weight oil works very well when soaking the leather packings. as long as it is a paint pump your ok. on the lacquer pumps we use throat seal. the leather is not as pliable. we always flush with solvent and water and end up removing the excess oil.
Old 03-23-09, 04:35 AM
I think I misunderstood
I thought you were using light weight oil in place of throat seal while the paint was being sprayed. I've used both as a lubricant during the rebuild process but only throat seal when pumping [spraying] paint.
Old 03-25-09, 06:08 PM
Smile Start up oil
Thanks everyone for your answers. I finally got through to Titan and they said 3in 1 oil or seperating oil is good . thanks again.
