Can I paint a fiberglass sink?
Old 08-16-00, 08:58 PM
Guest
Question
I wonder if anyone has tried painting a fiberglass sink? Or knows of someone who did? I'd like to try but what paint would I use? Epoxy? Exterior? Polyurethane?
The sink isn't used very much - it's in the laundry room but is stained and I would like to brighten it up a bit.
Old 08-17-00, 06:53 PM
mikejmerritt
Post
If you want it to stay you will have to use a fiberglass refinishing kit.It comes with an etching prep and a 2 part epoxy.Be sure you get one for fiberglass,not ceramic.
Old 08-17-00, 08:32 PM
Guest
Post
Thanks for the reply. However, it sounds more expensive than it's worth! Is there a less expensive way if I'm not too particular about how long it lasts? If not we'll probably just buy a new sink.
Old 08-17-00, 08:49 PM
mikejmerritt
Post
The kit should be about $15 or so and is fairly simple to do.You will have to weigh the cost of the kit and your time.No common paint will bond long enough to justify doing.
Old 08-17-00, 09:12 PM
Guest
Post
Fifteen doesn't sound so bad. I'll have a look for the kit. Thanks!
