Painting a curve
Old 08-16-00, 07:45 AM
Guest
Post
I want to be able to paint a room in 2 colours, with the join as a curve, rather than the more normal straight line. How do I make sure the line looks good (i.e. no overlap with colour) and continuous?
Old 08-18-00, 03:40 AM
mikejmerritt
Post
If you draw roughly the lines you want with a pencil,using 1/2 masking tape you should be able to follow the marks with no trouble.I say this because I do it often while painting auto parts.Does seem helpful in following curves to lay the roll of tape in the sun prior to using.Hope this helps some....Mike
