Paint an old aluminum door
Received 0 Votes
Hi,
I'm looking at refinishing an old but in very good condition
aluminum combo door from the 60's.
I wire brushed and sanded the chalky, pitted surface, and it's ready for a nice glossy finish.
Aluminum should accept most metal coatings, right? Should I pop it off the hinges and spray it on a two-by-four?
The Atlantic Ocean is about five hundred yards away; offshore winter winds are brutal; a very corrosive condition for any metal, let alone aluminum.
So, what sort of coating is recommended.
Thanks
Thanks
Were you able to remove all the chalk?
Generally aluminum can be painted with oil base or latex paint. If the aluminum is thin enough to expand/contract with temp changes, you should use latex because it's flexable - oil base is not.
You should go to your local paint store [not dept] and discuss it with them. They will be able to recomend the best coating [s] for your needs.
Received 0 Votes
Any time your contemplate painting a metalic surface, aluminum, copper, galvy, etc., you need to put an etching primer on first. Pratt & Lambert Poly Clutch is the brand I use. Every company makes their own so ask where you buy your paint. If you skip this process, your job just plain won't last.
Bill
Bill
There are times when special primers are needed when painting metal but as long as the chalk has been dealt with, there isn't any need for a special primer when repainting most aluminum.
Received 0 Votes
I disagree. I've painted a number of aluminum sided houses without using a primer and the paint job on all of them have held up for over 10yrs. I'd clean them and then spray a coat of quality exterior latex with some emulsa bond added [to bind up any chalk that didn't get removed]
