Paint the inside of an outside door
Old 09-24-00, 05:32 PM
Guest
Question
What is the best method and paint for painting the inside of a metal outside door (the front door) that has already been painted?
Thanks!
Old 09-26-00, 09:33 PM
Guest
Post
I can't do best, but I can recommend durable. Oil base Industrial Enamel is durable and so is acrylic automotive body paint. The best method is spraying. I doubt that you have a spray rig and booth, so after wet sanding, apply brush coats of Industrial Enamel and wet sand lightly with
600-800 grit wet or dry sandpaper between thin coats. And for the final coat use automotive rubbing compound. When you're done you should have something that resembles an automotive finish and is as durable as the coating on the dividers in a public bathroom.
Old 09-27-00, 08:35 AM
Guest
Post
hi
i have use regular oil paint on the inside of a metal door and it looks great and is lasting fine (painted 7 yrs ago and is the main door for 2 active boys.) i did not sand first just cleaned it well. and only used 2 coats (its a burgandy/red colour)
