removable window mullions-easy way to paint
Old 11-06-00, 11:31 AM
Guest
Question
Is there a trick or easy method to paint both sides of the removable mullions from windows and doors? Especially since the back, or part that faces outside is painted a very dark solid color and the inside part that would be visible inside the house will be painted white. Any helpful suggestions would be appreciated as I'm sure there has to be a trick to this.
Old 11-06-00, 06:50 PM
Guest
Post
I would remove them and paint one color at a time, allowing to dry between coats and colors, and paint the sides the same color as the exterior (if applicable), you could tape some newspaper on a wall and floor in the garage to lean them on to dry.
