remove paint?
Old 06-16-09, 03:38 PM
remove paint?
How do I remove dried paint from wood trim? Do I sandpaper it?
Old 06-16-09, 06:34 PM
C
If it is just a spatter or two. then sandpaper might be enough. Otherwise, paint stripper is normally best.
Old 06-17-09, 05:03 AM
Received 229 Votes on 204 Posts
How much paint?
If the woodwork is painted with oil base enamel and the splatters are latex - products like 'goof off' or 'oops' may work. Often just 'scratching' off the offending specs is best.
If you need to completely strip the paint off the wood - sanding, paint stripper and even using a heat gun and scraper are all options.
Old 06-17-09, 05:41 AM
B
Your question is a little vague, interior, exterior, what are you doing to the trim after the paint is off? There are instance when replacing the trim may be the best option...
Bill
