Dark Gray Paint - scuffed?
I have a very dark gray accent (flat, no gloss) wall that got "scuffed" by some cardboard boxes I was carrying. There are 4 coats of paint and I didn't bump the wall very hard.
However, the contact left the dark paint with a kind of powdery lighter colored streak/discoloration. I'm not sure if I permanently scratched the paint or if I can just scrub it out (too scared to try). Thanks for any help!
Gently - flat paint doesn't usually take well to scrubbing. I'm not as confident as Mark, I think you may have to repaint.
Flats may touch-up better...
You're "lucky" in a sense that it's a flat!
Flats touch-up the easiest of all the sheens.
1st however...
* Lightly clean the smudges off using a very slightly damp cloth that doesn't lint.
* Use soft "blotting" motions...NOT horizontal scrubbing!!
* The "streak" you're seeing is actually the cardboard residue!
Flats are a "coarser" surface finish, with little smooth "binder-resin", which helps higher-sheen paints wash well.
2nd step...
* When area is dry, dab on a FAINT trace of touch-up paint from lint-free cloth.
* IF you can hardly see it...it's enough.
* Wait an hour to see if more is needed. Keep lightly building-up the touch-ups.
* The whole key is the layering of barely-visible touch-ups!
Faron
1st however...
2nd step...
Faron
the streak is not cardboard residue. It sounds like it is a dark color. These are notorious for "marring" or doing exactly what you are seeing. You should be able to touch it up fairly well because it is a flat. There is no permanent fix. You could repaint with a shinier paint, it will help a little. There are very very few paints on the market that are specifically designed to have minimal marring and when they do mar, the mark will be slightly dark so as to be less noticeable. It took the chemists at the company I work for a few years to develop such a product.
