Tape/Caulk Issue
Old 08-27-09, 11:33 AM
Z
Tape/Caulk Issue
I know taping trim and edges has been addressed numerous times, but I haven't found a clear answer to my issue.
I'm absolutely sick...that feeling when you try so hard to do something so well and fail miserably.
We laid blue painter's tape over our trim and left about 1/8". We then caulked all the seams. I'm guessing part of my issue is a caulk bead that was too thick. After painting, we've tried to remove the tape, and we're having to use a razor for it all to release.
Well, I can't seem to cut a straight edge to save my life. The paint edge is wavy (I know this is not the optimum method for cutting in). Is there a reasonable solution or technique to help with this issue?
Old 08-27-09, 04:06 PM
Received 786 Upvotes on 689 Posts
Welcome to the forums!
You should have caulked [and let it dry] prior to using any tape. A razor or utility knife is the only option you have. A straight edge [maybe a wide drywall knife] might help you cut a straighter line.
Old 08-27-09, 07:32 PM
Z
Ok, so caulk, then paint. I'll definitely give that a try for the rest of the house. I appreciate the advice.
I did go back with the utility knife and took some extra time to clean things up the best I can. It's not 100%, but it is much more satisfactory. My perfectionism and skill level don't always add up!
Thanks again.
Old 08-28-09, 03:54 AM
Your welcome
I probably should have mentioned that tape can be problematic. If you must use tape it's best to remove it while the paint is still wet. This will prevent the paint from forming a bond between the wall and tape. If you wait until after the paint dries, it's best to cut the edge of the tape to sever the bond - failure to do so will often cause paint peeling along the tape's edge
