tannin oils are not my friend
Old 05-18-10, 12:35 PM
Please help, I am going crazy! I have a mahogany bed that I deglossed, cleaned, primed with a latex primer and 2 coats of white paint. 2 weeks later it is completely pink. I have stripped all the paint off, sanded and re-primed with Kilz oil based primer (2 coats) and I am still seeing peach/pink color bleeding through the primer. I am afraid to even bother coating it with paint at this time for fear it's still going to bleed through. Anyone have any suggestions before I simply give up???
Old 05-18-10, 02:18 PM
Received 153 Votes on 136 Posts
Welcome to the forums!
The oil base kilz might be enough to stop the tannins from bleeding thru the top coat. Applying a coat of pigmented shellac primer [like zinnser's BIN] should guarantee no bleed thru.
Old 05-18-10, 08:29 PM
XSleeper's Avatar
Received 283 Votes on 259 Posts
I second the BIN recommendation. It's great. But it dries fast!
Old 06-07-10, 05:44 AM
tannin oil
ok, I used the BIN primer and yes it took some time to get used to it beetween how fast it dries and it's consistency. I have applied 3 coats of it and I think I need another however, it seems to be working since I can only see a little bit of pink bleed through here and there. If the 4th coat of primer and coat of paint doesnt work I think I will just paint it pink and give it to someone with a little girl since my son defiinately wont sleep in a pink bed
Old 06-07-10, 07:43 AM
I can't imagine anything bleeding thru multiple coats of BIN. You might want to try the finish paint on 1 section - I'd expect it to be alright
