Primer for Appliance Epoxy?
I had used some dilluted water and bleach to clean off my stove before applying appliance epoxy but it has loosened in spots. Is there a primer I can apply to increase adhesion? or do I need to sand the original surface? Thanks.
What does the instructions on the epoxy say?
When you washed it down with the bleach water did you rinse off the cleaner well? Sanding is almost always a needed step when painting over any type of glossy paint. Are you painting the entire stove? or is it just some touch up?
