cleaning walls before painting
Old 12-01-00, 11:37 AM
Guest
Question
The people before us smoked. I need to clean the walls and ceiling and then paint. What should I use to clean the walls and should I rinse after? How long should I wait to paint?
Thanks
Old 12-01-00, 03:33 PM
Guest
You come to the right place, here is a page on cleaning walls: http://doityourself.com/patch/prepaint.htm
If this does not help please post back.
Chip
P.S The ingredient mentioned tri-sodium phosphate can be found at most paint stores, called TSP.
Old 12-05-00, 09:20 AM
the_02860
I have also used a product called 'Dirtex' which is available at most hardware stores or Home Depot. It works well for this purpose.
Todd
Old 12-10-00, 05:27 PM
Guest
painting over smoke-stained walls
Yes the other replies were correct. However, I have come across smoke stains that no amount of washing would remove. There are sealers that were created for the purpose of sealing smoke stains, water stains, ink, etc. There is one called B.I.N. that is excellent but the fumes are atrocious. Nowdays I use either Z-Prime or Kilz. Both come in water-based formulas. They are more expensive than most interior paints, but believe me, if you value your time they are well worth it. You just paint it on and when dry top coat with any kind of paint you want. Hope it helps.
