Minwax polyurethane sprayable?
Old 02-24-11, 08:54 AM
E
I wondered if I can spray Minwax Fast-Drying polyurethane on some shelving I've just made. There are no thinning recommendations on the can, so don't even know if this is possible/recommended. I was planning on using an HVLP gravity feed sprayer.
Thanks in advance!
Old 02-24-11, 10:24 AM
Received 821 Upvotes on 720 Posts
It can be sprayed. How much to thin depends on what type of sprayer you are using. I've sprayed it straight out of the can with an airless but a conventional cup gun will require thinning to get it atomize properly.
Old 02-24-11, 12:16 PM
E
Thanks - I'll give it a go and do some experimenting with thinning ratios.
Old 02-24-11, 01:22 PM
Start off slow with the thinner, you can always add more but it's kind of hard to thicken it back up
