Peeling Trim Paint
Old 03-19-11, 11:34 AM
P
Peeling Trim Paint
Hey Everyone!
My first post here. I see lots of good advice. Hope that someone here can help.
Here's the issue: I have a semi-gloss trim that I would like to paint over. I painted over a decent size section of it with flat paint, no primer or anything else, for the sake of seeing if I like the color. That paint is now peeling off. I can scrape it off with a putty knife or my finger nail. The trim is a complex surface, so scraping it all off is not an easy thing.
I have 2 questions:
1. What should I do with the paint that wont stick? If I should remove it, what is the best way?
2. What is the best way to prepare the surface so that I can paint another semi-gloss finished paint over it. (Assume existing paint and new paint are both latex water based)
Thanks!
Pat
Old 03-19-11, 02:35 PM
P
Temporarily Suspended
You have to remove the paint that is peeling. I would scrape first, then sand.
Old 03-19-11, 02:40 PM
Received 398 Votes on 354 Posts
Welcome to the forums Pat!
I'd rather not assume the existing paint is latex as an oil base enamel would cause the peeling
http://forum.doityourself.com/painti...latex-oil.html
Generally a light scuff sanding will allow quality flat latex paint to adhere without any issues to latex enamel. Did you happen to use one of those small sample paint cans - they're kind of cheap and not formulated for wear or adhesion over tricky surfaces.
Aggressive sanding should remove any paint that isn't stuck good enough. I'd start with 80 grit - that should remove what needs to come off, then use 120 or 150 grit to sand out any sanding scratches. You could also use lacquer thinner or a product like 'oops' or 'goof off' to dissolve and remove the flat paint - but if the underlying paint is latex, it might partially dissolve it too
If the existing enamel trim paint is oil base - you'll need to use an oil base primer before you can switch over to latex.
Old 03-19-11, 03:34 PM
W
I would also think that a latex conversion primer something like Zinsser's Bullseye 123 would work as well. Would remove the need for an oil based primer. Easier to work with for a DIY.
Other than that, I'd agree with everything Marksr said. Oil based primer would obviously work as well, just messier to work with and clean up is a pain.
Old 03-20-11, 01:33 AM
P
Oil based is suicidal & I doubt it's needed.
Old 03-20-11, 08:28 AM
P
Right on. Thanks for the good input. You're right, it was one of those sample colors. Looks like I have some work to do, and some things things to figure out before I paint, but better to do the rest right and not have to deal with this again.
You guys Rock!
Pat
