How should I paint my new drywall??
#41
"I've also read elsewhere that the primer can raise the fibers in the paper on fresh drywall. Sanding after will get rid of that"
Very true, it isn't uncommon for the areas of the drywall that aren't covered with j/c to become a little rough from the primer coat. Some primers seem to be more affected than others.
You might not have a lot of success sanding out any roller marks. Often it's easier to apply a thin coat of spackling or j/c to those spots, sand the j/c lightly and then reprime those areas.
#42
Received 0 Votes
Ok.. Priming almost done! 10 gal so far! I think I can finish with just one more gallon.
I still have the shower ceiling to do. Should I get an additive to the primer for Mold/Mildew? Or just for the final coat? There is a fan in the shower that will be on when the shower is going to remove the majority of the moisture.
Also.. I'll be starting to paint the door casings and moldings. I want to try my new
HVLP sprayer. What type of paint should I try? I have a 1.4mm and 2mm nozzel set for the gun. I want a gloss finish to match the rest of the house trim. At least I think it's gloss.... If I use semi-gloss I should add the floetrol, right?
I get the feeling it will be trial and error to get it right! I have a ton of trim to spray so I don't want to have to brush it all!... plus it's a new toy to play with!
#43
I wouldn't worry about additives in the primer, the paint would be where you'd do that - are you planning to use a kitchen and bath paint in there?
I don't have enough compressor to run a paint gun, we'll have to wait for Mark on that one.
#44
Received 0 Votes
#45
You need something, K&B paint or an additive - I tend to like higher gloss paint in a bathroom so I'd get a different paint, your option makes sense if you want the same paint in multiple rooms
#46
If I'm not mistaken, the mildewcide packets are for exterior use only...... but it will work inside. The air quality in the room might not be up to standards until the paint has cured. Latex enamel [any sheen] is bare minimum for a bath rm walls/ceilings. Kitchen and bath paint is preferred.
While I have a few HVLP conversion guns [operate off of an air compressor] I don't own and have not used a true HVLP. The conversion guns are almost useless for spraying latex paint - it has to be thinned way too much..... but you won't know til you try - use your biggest tip. Floetrol is a good thinning type additive for most any latex paint but I don't know if it will be effective with a HVLP.
#47
Received 0 Votes
What do you guys prefer for Trim? Semi-gloss or gloss? I think the rest of my house is gloss...
I'm really tired of painting!
priming -> Done!
Ceilings -> Done!
Daughter B-room -> Nauseating Pink Done! (I call it the pepto-bismol room!)
b-room closet -> not done
Rec room -> started.
Storage room -> not done
Linen closet -> not done
bathroom -> not done
hallway -> not done
Trim and doors ->
I think I may put all the outlets in the b-room just to take a break from painting!
Jim
priming -> Done!
Ceilings -> Done!
hallway -> not done
Trim and doors ->
Jim
#48
I generally prefer gloss on the woodwork but it all boils down to personal tastes. I've painted a lot of homes where we used a satin enamel on the woodwork. The woodwork should always be an enamel and have a sheen equal to or greater than the sheen that's on the walls. When given a choice, I like to use the trim enamel on the closet walls and wood - it will help the paint job to look good longer - that way you won't have to repaint the closet every time you repaint the room
Since you have gloss on most of the woodwork, I'd be inclined to stay with gloss for the rest.
#50
Received 0 Votes
I like the look of stained trim myself but I wan't going to mix and match!
#51
Yep, you're going to need to paint yours.
As Mark said, at least as much sheen on the trim as the walls and try to keep that sheen on all trim, so I would stick to the gloss like you've already been using.
#52
Received 0 Votes
Update... Just so I can see my progress!
priming -> Done!
Ceilings -> Done!
b-room closet -> Done just one coat.. good enough!
Rec room -> Done!
Storage room -> Done!
Linen closet -> Done in ceiling white!
bathroom -> not done - Still waiting to pick a color!
hallway -> Done!
Trim and doors -> Not done but next on the list!
I'm getting there!
priming -> Done!
Ceilings -> Done!
Rec room -> Done!
hallway -> Done!
I'm getting there!
#53
Received 0 Votes
I started spraying my door jambs and trim on my split-jamb doors. It was interesting
trying to use the sprayer for the first time. I ended up doing a 16oz of paint, 4 oz floetrol and 4 oz of water. That seems to be ok. I had issues with not enough pressure. Once I took off my inline filter/dryer the pressure was much better. I guess the amount air required was too much for the filter or maybe I need the bigger connectors. Or maybe I should just connect the filter to the gun and not have connectors.. Anyway.. when the finish first gets sprayed on it didn't look too good and I thought I would have to brush it all anyway. But after a while I guess the floetrol did it's thing and the finish was smooth!
I was spraying upstairs in the room I'm finishing. I got a dust all over the rest of the house (I forgot to close the door). Is that from me kicking up the drywall dust that remained on the floor? Or might it be dried aerosolized (is that a word) paint dust?
Jim
Jim
#54
You have to be careful when spraying, especially in an occupied dwelling!
Drywall dust is easy to remove although it will kind of revert to joint compound if you get it wet.
Overspray is the big concern! Hopefully it is fine enough and was dry enough when it landed that it didn't bond to the surface. I'd try wiping first with a soft rag, if that doesn't work try scrubbing with a little soap and water. If that doesn't remove it all - use a product like 'oops' or 'goof off' They are very effective for removing dried latex paint and won't adversely affect most finishes - always test an unseen area first!
#56
Depending on conditions, overspray can go a long ways
The further it travels, the more likely it will dry and not bond to whatever it lands on. That's why I rarely spray inside an occupied dwelling. Sounds like you got lucky - hope the "boss" didn't get too upset
#58
Received 0 Votes
If you're painting flat paint over drywall, primers are mostly a waste of time. "They" claim that buying primer will save money, but let's take a look at that. Let's follow recommendations, for 1 coat of primer, and 2 coats of paint. Let's say you're buying $15/gal primer and $30 paint. Let's say you have a 15x12 room with 9 foot ceilings to paint. You're going to need 2 coats of primer and 3 gallons of paint, for $120.
Now let's say you skip the primer, and go straight to paint. The walls will look the same, but it will cost you $90.
The primer route is only cheaper IF:
- you put on 1 coat of primer and 1 coat of paint
- the room just happens to be small enough to cover with 1 gallon
But even then, it's still not worth that much. Let's say you have a 10x10 room with 8 foot ceilings. If you're going to put on 2 coats of a neutral color, you might as well save money and just buy 2 gallons of the paint. For example, you'd be better off putting on 2 coats of Sherwin Williams Master Hide (cheaper paint at about $15), than 1 coat of primer followed by 1 coat of Sherwin Williams Super Paint ($15 + $45). So again, why the primer?
Especially if you bump up to a high quality paint like $45/gal, primer buys you nothing because there is so much solids in the quality paint. You can even put a single coat over drywall and have it look good, if the paint is good and the color isn't radical.
Eggshell or glossier paint is a completely different story. Now you will not get poor results due to sheen differences, because different areas of the drywall have different porosities. Now you can still probably get away with 2 full coats of a quality eggshell, but for best results you want to cover the drywall with a SEALER first (not necessarily primer). The sealer can actually be clear (but if you want to cover with 1 finish coat of a dark or bright color, a tinted primer/sealer would be the best. The important thing though is to seal off the paper and joint compound when using paints with sheen. Zinsser Gardz is one such sealer.
#59
Received 0 Votes
Zinnser's Gardz is primarily used to seal drywall after wallpaper removal. It will do a decent job of sealing most any drywall [not stains] but it really doesn't have any hiding properties so painting over it would be harder to get coverage than painting over most any other primer.
Most any paint with a sheen can have gloss retention problems especially when you need to touch it up. Using the right primer [latex enamel undercoater] will go a long way towards helping the enamel to have a consistent sheen.
#60
Received 0 Votes
I've never used Zinsser's Gardz primer, but my understanding is that it's intended to be used over damaged drywall paper, not as a general purpose primer. I really don't know what Gardz is or how it works, so I can't comment on Mr. Pauhl's assertion that it's a drywall "sealer" without also being a drywall primer. I do know that Gardz is a relatively unique product, and that the vast majority of drywall primers are also drywall sealers for the reasons explained in my previous post.
There's nothing wrong with using a paint as it's own primer, it's just that you're going to get different results depending on the gloss level of your paint, the porosity of the drywall paper and joint compound, and other factors. What really matters is:
1. How well is the paint holding on?
2. Does the paint stand up well to scrubbing, moisture/humidity, and am I happy with it's performance? Is it easy to keep clean?
3. How good does the paint job look? (You want to see a UNIFORM gloss level everywhere.)
I'd also do your testing on an area of wall or ceiling where you can see the reflection of light from a window. In my case, I rarely prime or paint over drywall. Most of the painting I do is over joint compound (as in repairing nail holes) or over paint. I think you'll find that the gloss level of a primer won't vary from drywall paper to joint compound, but the gloss level of paint will vary considerably depending mostly on it's gloss level. I expect joint compound will absorb a lot more paint than paper, and I expect you'll find that's especially true as you go to using higher gloss paints as your primer.
In a nutshell, it's not uncommon for people to use a paint as it's own primer. However, if that gave consistantly better results than using a primer, Mr. Pauhl wouldn't be the lone wolf calling in the wilderness. It would be widely known, and everyone would be doing it. Mr. Pauhl's results just aren't typical of most people's experience, and I expect he'd get different results too if he used different paints as primers.
#61
For sheen consistency, you're better off using sealer like Gardz. Most primers are white, so painting over white drywall with a coat of Gardz is no different than painting over white primer. ...... Painting sheen paint over bare drywall or joint compound you're going to have different porosities and thus sheen retention problems.
I would never recommend not using some type of primer over bare drywall. Not all primers are the same - that's why there are so many of them
The main thing to note is most repaints don't need a primer and when a primer is needed - it pays to get the right one!!
#62
Received 0 Votes
Can you give me an example of a "latex enamel undercoater"?
#63
SWP - all surface latex enamel primer, their A-100 latex exterior primer also works good on interior woodwork.
BM - super spec latex enamel undercoater, they also have a waterborne enamel undercoater although I've not used it.
PPG - seal grip latex enamel undercoater.
Gilmans - I don't remember the exact name on the label but it's the best latex enamel undercoater I've ever used - haven't bought or used any since I retired.
