Paint wood cabinets
Old 01-29-12, 06:57 AM
D
Paint wood cabinets
I want to paint my natural wood kitchen cabinets with latex showing no brush strokes. Should I use a sponge, roller or latex brush? Perhaps you have another suggestion! Thanks., Bob
Old 01-29-12, 09:41 AM
Received 785 Upvotes on 688 Posts
What kind of finish is currently on the cabinets? Latex paint won't adhere well to most solvent based finishes. Generally you need to start with sanding and then a solvent based primer. Latex will then adhere to the primer. Latex paint can be the hardest type to eliminate brush marks. Sanding between coats helps. Also use a reducer like x-tends or floetrol will slow down the drying time allowing the paint more time to flow together. Those with poor brushing skills often find a little roller stipple to be preferable to brush marks.
Here are some links that might help you,
http://www.doityourself.com/forum/pa...latex-oil.html
http://www.doityourself.com/forum/pa...t-repaint.html
