Newly painted walls and now water stains after cleaning a bit
Old 04-19-12, 05:49 PM
G
had my walls painted with glidden premium satin finish i beleive..and i had floor people come in and they left some marks on the walls so i went to wipe with a soft cloth and a little bit of water and now that water spot will not go away. its been 4 hours and the spot is still there..im hoping tomorrow it will go away but if not what in the world is going on? can i not wash my walls now? also its been over a week since the painting was finished.
thanks
Old 04-19-12, 05:57 PM
XSleeper's Avatar
Received 644 Votes on 596 Posts
You probably buffed a shiny spot on the satin finish. Generally, the higher the gloss the more washable the surface will be. So no, satin is probably not your most washable finish.
Old 04-20-12, 04:46 AM
Received 301 Votes on 267 Posts
While satin enamel might not be as washable as a semi-gloss or gloss - it should still be washable..... that said, when it doesn't clean up well, you can touch it up with paint. The painter did leave you some leftover paint, right?
