What type of spray gun I should buy from Harbor freight to use with air compress
Old 09-25-12, 06:12 PM
V
Question What type of spray gun I should buy from Harbor freight to use with air compress
I am looking at harbor freight website to buy a spray gun to paint exterior on shed in backyard.
the paint is latex .....
I have a hausfed brand 2 hp air compressor which has 2 tanks..
Am not sure if I should buy hvlp gun or lvlp gun or what?
Please advice?
also I have lots interior paint...can I use it outside like 5 layers or more?
or I must have exterior paint?
Old 09-25-12, 07:24 PM
Tolyn Ironhand's Avatar
Received 780 Upvotes on 660 Posts
Neither. You should be buying a airless sprayer. With the other guns you will need to thin the latex too much.
Old 09-25-12, 09:24 PM
V
hand roller
I think I should use hand roller instead of buying gun...
Old 09-26-12, 04:37 AM
Received 785 Upvotes on 688 Posts
Ya, a roller would be a better choice. Cup guns [and pressure pots] are only for spraying thin coatings and work best when the coating is solvent based. Latex paints would have to be thinned too much for conventional spray and the air that passes thru the tip would also dry the paint and cause constant cleaning. Also painting requires a LOT of CFM and small compressors don't do a good job of supporting a spray gun.
Airless spray units are made specifically for this type of spraying but to get a good job the sprayed coating should be backrolled to work the primer/paint into the substrate. I've bought a lot of tools from HF including some HVLP conversion guns but I'd be a little leery of their airless units, I don't believe you can get any kind of quality at that price. You can rent airless pumps that are halfway decent.
Old 09-27-12, 09:16 AM
C
With respect to the paint available, exterior paint is exterior paint, interior paint is interior paint. Exterior paint is formulated to be exposed to the elements and endure. Interior paint is not so formulated and will likely fail soon. With painting, the expense is in the labor. No point in applying interior paint outdoors then having to remove it and do it right,
For such a small project, it does not seem wise to buy a sprayer rather than a $10 roller set. Plus, there is a learning curve for a sprayer.
Chris
Old 09-27-12, 06:16 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
With the disclaimer that "I don't paint", cleaning a paint gun will take as long as it would to roll paint on the exterior, IMO. I don't think it would be more beneficial to use a gun on this application.
