oil base paint
Old 01-27-01, 04:50 PM
Guest
Exclamation
ok, if i have oilbase paint on my door trim, and i want to paint it, can i just use oil base paint and paint over it, or do i have to do alot of preperation to it, basically i want to paint it with as little time involved as possible and move on to other things, but i want it to look good
Old 01-28-01, 04:59 AM
Guest
Oil based on oil based, yes with a clean surface and lightly sanding with a 220 grit prior to re-painting and useing a quality paint you will have no problems with adhesion. For best results get a pro paint brush and depending on the consistancy of the paint, can be thinned a little for less drag and smoother results, 2 coats may be nesasary for best coverage.
Hope this helps.
