Flashing and Uneven Coverage
I have been unable to determine the cause of this problem. I painted my ceiling and areas of flashing/uneven coverage are visible. I had a stucco ceiling, which I scraped flat. I used a light mist of water from a spray bottle to slightly moisten the stucco, then I gently removed the "popcorn." I then let it completely dry, i.e. at least 24-48 hours, maybe even a bit more. Then, I skimcoated the surface with an all-purpose joint compound thinned with water. After that, I primered twice, once with Kiltz for drywall; a second time with a Sherwin Williams high build primer. I painted the ceiling three times with Sherwin Williams Eminence Interior Acrylic Latex Ceiling Paint. I used a 3/8" nap synthetic roller cover the first two times, then a 1/2" the last time. I suspect the problem is the quality of the paint. A guy at a local hardware store recommended that I thin my "mud" with a cheap paint instead of water and that I should try a topping compound. Any ideas as to what's causing the flashing/uneven coverage.
Welcome to the forums Jeff!
I've sprayed a lot of the SWP hi build primer but don't recall having used that line of ceiling paint. A better line of paint along with the 1/2" roller cover should help. I've had good results with their ProMar 200 paint on ceilings. What direction are you applying the paint in? are there any lap marks in the hi build coat?
What the guy at the hardware store is suggesting is for you to mix paint with thinned downed j/c and roll a texture on the ceiling.
Mark,
Appreciate the welcome!
The skimcoat looked like a level 5 finish, and the primer flawless. That's why I suspected the quality of the paint, even though it was a SW product. I used a "W" pattern when applying the paint, all in the same direction.
I'll give the ProMar 200 a shot although I've read good reviews about Behr on Consumer Reports.
Thanks again for the quick reply!
Forget the W or M pattern. That might be your problem as that limits the amount of paint you are putting on the ceiling. I always roll a straight shot and reroll the previous roller full once the cover has used up most of it's paint. Don't try to squeeze all the paint out of your roller. keeping the roller well lubricated with paint makes it roll easier and puts more paint on the wall/ceiling giving a better looking job.
