Painting a wall black
Hi, I am paiting my wall so that I can use the projector. Outside the screen area I want to make it flat black. The guy at Sherwood-Williams suggested I use a spray-can (Krylion flat black) with no primer as I am paiting on top of the previous paint.
I tried it; I think I might need a total of four cans for the first coat (the wall below is light yellow). The problem is that the can creates a lot of dust, not a big deal, I can vacuum it and it cleans well, but it's still a lot of work.
What do you think the advantage of the spray-can is? Should I switch to "regular" paint that I apply with a roll? As you can see I am not an experienced painter
Personally I would roll on a flat black paint with a thick nap or textured roller. The texture will help hide imperfections in the wall and if light hit's it's uneven surface it will scatter it better than a very flat surface. Outside that I'd consider curtains or fabric covered panels instead of a painted wall.
If your wall is quite perfect and you do a great job with the spray cans you might get an acceptable finish but it will be tough. The spray pattern from a can is roughly circular so it's hard to get even coverage.
That dust is paint. Using an aerosol can is very inefficient so only a portion of the paint you spray is ending up on the wall. If it dries before it hits a surface you've just got dust but if it's still wet you could have a mess on your hand. So, put drop cloths on everything and take off your paining shoes before stepping onto a good surface. Also, I highly recommend a cartridge style mask in addition to as much ventilation you provide.
Hi! Well it was very easy to clean with a shop vac, even the one that landed on the white sofas. And I used a cartdrige mask.
But, if you say paint with a roller is better, that is perfect to me. The part of the wall that I want to paint black is already textured, in fact I had to finish the screen area with joint compound to make it perfectly flat.
So I just go to a paint shop and buy flat black paint and a big think roller. Any suggestion which paint I should get?
Go to Porter Paints or Sherwin Williams pick up a gallon of flat black and roll it on, That way you will have a smooth finish as spray cans tend to have runs if put on to heavy. Also its easier on the fingers.
Hm the area I want to cover is about 70 square feet. Let's say an equivalent of ~150 square feet for two coats... Maybe a gallon is a little too much, I asked at the store and they only have the one gallon size, the quart is order-only for the "Superpaint" flat sheen variety.
A gallon of paint generally covers 300 square feet or a little more (maybe 400 if you're lucky). So it does look like a gallon is more than you need but check the price on the quarts and I bet the gallon is pretty close to the same as two quarts.
If the 70 sq ft already has a coat of black on it - 1 qt of black paint is probably enough. Unless the wall texture is extra heavy, 1/2" nap should work fine. I rarely buy qts of paint, I'd buy a gallon, expecting to have use for the remainder later on...... but if you don't expect any future use for the paint and the wall already has a coat of black - 1 qt should finish the job.
The SWP employee that recommended using a rattle can must of been a new hire. If you go back to the same store, mention the bad advice given on the previous visit and maybe they will give you a discount on your next purchase.
