Painting stucco
Old 02-01-01, 02:57 AM
Dick Wyatt
Had a sunroom added two walls are stucco, same as the outside. How hard would it be to repaint them?
Old 02-01-01, 04:57 AM
Guest
If it is true stucco then you will need to ask the stucco company how long they recomend you let it cure before painting, then I recomend priming with Sherwin Williams Preprite interior masonary primer, alloy to dry and two coats of quality interior wall paint. If it is EIFS (exterior insulated finish system), then you can paint right on top with a quality latex paint.
Hope this helps.
Old 02-04-01, 03:44 AM
T
What the heck is "stucco"????
[Edited by Chipfo on 02-04-01 at 09:56]
