Painting Laminate
Old 01-14-13, 02:20 PM
D
Dig
Dig is offline
Painting Laminate
Is it hard to paint over formica? I have some cabinets and counters in my office that are an awful color and someone told me to paint them.
Does this method look good? Is it durable? What is the best product to use?
All help appreciated.
Old 01-14-13, 02:33 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Laminate is basically a slick surface, so just about anything you put on it, including paint, will come off in a short time. Our paint guy will chime in here shortly, and he may have a solution.
Old 01-14-13, 02:37 PM
Received 757 Upvotes on 662 Posts
It's never a good idea to paint formica. If you do paint it, sand first and then use a pigmented shellac like Zinnser's BIN for a primer. The BIN can be top coated with latex, waterborne or oil base enamel. You might get lucky on the cabinets but unless the countertops get no real use - I wouldn't expect the paint to hold up long term.
Old 01-14-13, 02:47 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
It may not be a real laminate...but whats called thermofoil. Formica is normally for countertops...but if the cabinets have flat square doors...Formica normally leaves a dark line at the joint of 90 degree surfaces. Thermofoil is used on cheap paneled doors. Sorta looks like a painted surface.
Plenty of hits on a search for painting thermofoil.
Old 01-15-13, 05:03 AM
D
Dig
Dig is offline
Thanks for the help.
I found something on the home depot website CABINET RESCUE 1Qt. Melamine Laminate Finish Paint.
It seems as you say that sanding the surface to break the finish the paint with this or again as you say to apply a primer then the finish may work.
It does seem that it may not be as durable as they make it seem.
Thanks for the information.
Old 01-15-13, 05:23 AM
Pigmented shellac has adhesion properties that are stronger than most any other primer or paint. I'd prime with BIN and then apply the paint. Have you read the painting instructions on that can of paint?
Old 01-15-13, 05:36 AM
Received 1,198 Upvotes on 1,153 Posts
Someone reported here a couple years ago that they had had good results using a kit made by Rustoleum just for painting countertops. Whether that would be a good choice for you I don't know.
