What Primer Will Adhere To Paintable Latex Caulk?
Received 0 Votes
I want to paint some window trim and paintable latex caulk with oil based enamel. Both are currently painted with latex paint. (This was a result of having replacement windows installed)
Based on my research in the archives, I believe for a lasting result the old latex paint and caulk should be primed first.
I bought some STIX Waterbourne primer which will work fine on the trim covered with latex paint but the can says any caulk should be removed before applying the primer.
Its not practical to remove the caulk, so the question is what brand of primer can I use that will adhere to the caulk so I can paint it and the trim with oil based paint?
Thank you
Thank you
Does it say "remove caulk" or "remove old caulk"?
I think they are probably just saying that the new caulking will stick better if it is applied to the primed surface. You can prime over the caulking, it will be fine.
With the exception of silicone caulk, I've never had any issues with applying primer over dry caulking although I'm not familiar with that particular primer. Generally latex paint doesn't need a primer to be top coated with latex or oil base paint.
Why are you wanting to use oil base paint? Personally I'd use a waterborne enamel. It dries almost as hard as oil base but dries faster and doesn't yellow over time.
Received 0 Votes
marksr
Plus, I think I'd have to prime the existing trim to cover it with waterbourne enamel, right?
Perhaps I should consider converting all future repainting to waterbourne even though it would require the extra step of priming first. Oil is a pita especially for a DIY'er.
The oil enamel you have should do a good job and it's nice to have all the woodwork painted with the same type of enamel. I just assumed you were changing from latex to oil base
I had one paint rep tell me that it was ok to use the waterborne over oil base but I'm not sure I trust that and haven't done it that way.... so I can't say with certainty one way or the other.
I used to be a firm believer in using oil enamel on interior woodwork but years of overexposure to solvents and the introduction of waterborne enamels caused me to switch to waterborne.
