Time between prep and painting?
Old 02-03-01, 07:18 PM
Guest
I preped paneling for painting up to and including the primer approximately a year ago. Now that I have finally decided on a colour for the rooom what fresh prep do I need to do? vaccum the walls? wash? new coat of primer? or can I go ahead and paint?
Also, how do I get old masking tape off the trim?
Old 02-03-01, 11:36 PM
Guest
You might want to do a light sanding with a fine grit and then use a tact cloth to remove any dust. Then go ahead and paint. As for the tape, try Goo Gone. It takes labals off so tape should be no different.
Old 02-04-01, 07:10 AM
Guest
Thumbs up
Agreed, also caulking the joints, trim, and corners will make a nicer looking job, after sanding and wipeing off dust, use a paintable latex caulk wipeing smooth with a wet finger and wipeing any excess or mess with a damp rag.
