will paint fix this over my digital piano?
Received 0 Votes
Hi, I want to get rid of this "thing" my dig.piano got over the surface of its metal case.
I believe its some kind of moisture, though it has some kind of worm-like shape (like some kind of tiny roots).
Anyway heres a few pics:
Im guessing I should somewhat clean the factory paint from the surface and paint it over (but dont know exactly how) (or maybe just paint over?)
About the metal its some kind of thick sheet metal, dont know exactly. Heres a pic of a scratch on the back that partially reveals some of the material.
Ok guys Im a total noob so I ask the experts, what should I do?? Thanks in advance!!
Welcome to the forums!
The metal parts should be sanded and primed before you apply any paint. What is the rest of the case made of? Can you feel any difference between the the good spots and those that look funny?
The biggest issue with repainting the case is whatever paint you use - it's not likely to be as durable as the factory finish
Received 0 Votes
The piano is made of two metal cases (one on top and one below) and 2 plastic endcaps to the side.
The upper metal cover is only compromised on the spots showed in the pics, other zones of the case are in good shape and smooth.
So what IS that on the pics? I would like to know, maybe you have seen it before, is it moisture, or maybe rust onder the paint??
Anyway, what kind of paint you recommend? Som sort of spray paint for cars?
Received 0 Votes
Hi, thanks for replying! Nope, there´s not any plastic film just the metal and the painting, wich will be hard to replace, im afraid about it getting worst after the paint :s
No problem with spraying though, since im dissambling the instrument before proceding, so ill be painting only the half of the case, but im still thinking about what kind of paint will be best for the job. Any suggestions?
Is it possible to get any painting input from the instrument manufacture?
An automotive paint would work fine on the metal but I'm not sure how well it would do on the plastic. Does the plastic part flex any? Krylon makes a paint for plastic so it might be better. I don't know how well it wears
Received 0 Votes
English is not my native idiom, so some words and expressions are beyond my understanding... whats a "painting input"?? You mean the letters painted??
As for the paint on plastic, theres no plastic part that needs to be painted.
There are parts that have letters, these parts will have to be protected and paint the rest of the case.
my concern is that the new paint to be much different than the original one and there be much contrast with the protected parts.
So how could I find the right paint?
Looks to be a difficult job with the lettering silk screened on. When you mask off the lettering you will always see a line where the new and old paint meet.
The metal is most likely aluminum.
Is that an SP-88 ?
Is that an SP-88 ?
