paint over wood -- real wood, untreated
Old 04-03-13, 05:46 PM
W
Hi Marksr or PJmax, different question : I want to paint over wood -- real wood, untreated -- that is a half wall. I don't know if it is pine or oak, but I want it to look as much like drywall as possible (i.e., I don't want to see the grain). How can I do that? Will putting on a coat of the pigmented shellac work? Should I sand the wood first?
Old 04-04-13, 01:57 AM
Received 3,485 Upvotes on 3,128 Posts
To get a smooth finish the wood needs to be sanded. I would think that the shellac would be a good choice first.
See what Mark thinks as this is his specialty.
Old 04-04-13, 03:41 AM
Received 759 Upvotes on 664 Posts
There is a big difference between oak and pine. Pics should help us help you identify it - http://www.doityourself.com/forum/el...-pictures.html
If the wood is old, it may need sanding to help the primer adhere better. If it's rough it needs sanding. Generally an oil base primer followed by 1-2 coats of your choice of finish paint [sanding between coats] will produce a nice finish. Oak often needs a filler for the grain although latex paints will fill the grain better than oil base finishes.
Old 04-05-13, 12:12 PM
W
Is an oil based primer different from pigmented shellac? I ask because I wondered whether I can prime the wood wall and the laminate shelves with the same thing. I'm attaching a picture of the wood wall. It's pretty clear it's not pine, but I don't know if it's plywood or oak. As I said, the idea is to no longer see the grain. I hope the attachment works . . .
Old 04-05-13, 02:05 PM
Pigmented shellac is the ultimate primer when adhesion or stain covering is needed. It also dries fast. Zinnser's BIN is the most commonly found brand. Almost forgot to mention - it's also the stinkiest
Oil base primers are generally adequate for priming over poly/varnish especially if the poly receives a scuff sanding first. You should be able to use the same primer over both the trim and the paneling. If there is any wax/polish on the wood it needs to be removed first.
Old 04-06-13, 09:55 AM
W
I've run into my first problem. What I have found is "Zinnser Bullseye Shellac Amber". Amber is a pigment but is that what you meant? Would it clash with my paint?
Old 04-06-13, 10:43 AM
Bullseye amber shellac is more or less clear with an amber tint and is used as a soft finish. BIN is a white pigmented shellac that is intended to be only used as a primer. I'm having internet connection problems - I'll try to provide you with a link later.
Old 04-06-13, 11:13 AM
W
It looks like the Home Depot guy pointed me to the wrong thing -- he insisted the Amber shellac was the only thing they had. Is this the right thing?
"Zinsser White B-I-N Shellac Interior and Spot Exterior Primer and Sealer"
Zinsser 1-Qt. White B-I-N Shellac Interior and Spot Exterior Primer and Sealer-00904 at The Home Depot
Old 04-06-13, 11:48 AM
W
Yep, that's the one. Home Depot definitely carries the stuff.
Be sure you can open windows and maybe even run a fan when you're applying this stuff. I'd also recommend running a fan and wear a respirator if you've got one.
I'd also recommend you use a disposable brush. This stuff is so sticky and dries so fast it'll likely kill any brush you're using. I've never met a painter who ever tried to clean their brushes they use with BIN.
Old 04-06-13, 12:02 PM
W
Thanks. I was actually planning to use and throw away a foam roller instead of a brush because I'm worried about brush marks. That's okay isn't it?
Old 04-06-13, 03:34 PM
I normally use an old roller, I can't say for certain if it will work ok with a foam roller - I never use them. Like most I normally use an old brush and toss it after using pigmented shellac although occasionally I'll need to use a brush I want to keep so I'll clean it with denatured alcohol. I've heard ammonia will also clean up pigmented shellac but have never tried it so I can say for sure.
