Adhering black paint to stainless steel bolt heads -
Old 06-24-13, 06:33 AM
GM to all! Just wondering if anyone knows how I might be able to adhere Black Paint to stainless 5/8 inch bolt heads. The paint keeps coming off. I tried roughing up the heads of the bolts with sand paper prior to spraying the enamel paint onto the bolt heads. Any ideas would be appreciated -
Old 06-24-13, 10:48 AM
Received 291 Votes on 259 Posts
It can be difficult to get anything to stick to stainless. What type of paint are you using? what primer?
I'd probably try roughing up the stainless with sandpaper and using either an etching primer or pigmented shellac and see how that works.
Old 06-24-13, 12:20 PM
Just using a semi-gloss black rustoleum - Thanks for your response!
Old 06-24-13, 07:09 PM
I'd be changing the bolts to something that's not plated.
Going to need a high heat paint.
Old 06-25-13, 03:11 AM
Why would he need high heat paint? am I missing something?
