paint or stain bathroom door?
Old 08-10-13, 04:47 PM
Received 1 Upvote on 1 Post
I am putting a plain flat door on the downstairs bathroom. It's a hollow core oak veneer door. What's the best choice to finish it. I could just paint it right now, our should i go ahead and stain it the color of the vanity wood?
Old 08-10-13, 04:52 PM
With the moisture in a bathroom and in a basement and it being just a cheap veneer hollow core door, I'd prime and paint two coats on all sides.
Old 08-10-13, 05:28 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Depends on the look you want. I'd hate to paint an oak door. If all the other doors are stained,then stain...if painted, then paint.
Stain with a clear topcoat will resist moisture just as well as paint. My doors are all flat and stained.
Make sure to seal all 6 sides, including under the hinges.
Old 08-11-13, 02:32 AM
Received 754 Upvotes on 659 Posts
Poly or varnish will provide as much protection as primer and paint. The main thing is to coat all 6 sides [with the poly] like Vic said.
