Chip in tub
Old 09-23-13, 04:59 AM
B
Chip in tub
I have a white tub that is chipped. Was able to get the color white that comes with the tub.I have put on a few coats and its a little higher than the rest of the paint.What would be the best way of making it even,so its not noticeable. Tub is metal but not cast iron.
Old 09-23-13, 05:09 AM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Not sure what kit you bought, but there is really nothing you can do.
Possibly have the whole tub reglazed by a pro, or they have kits for the whole tub that you can do yourself.
Old 09-23-13, 09:24 AM
Received 756 Upvotes on 661 Posts
Unless you are willing to go thru the trouble/expense of having the tub reglazed or lined - I'd call it good and move on to something else. Chances are you'll forget about it not having come out perfect once you've turned your attention to something else. You've probably done all that can be done without redoing the entire tub.
