trim prep
Old 02-24-01, 06:43 PM
Guest
Question
when patching nail holes in wood trim around windows is it ok to use a drywall patch or should wood putty be strickly used before painting?
Old 02-25-01, 06:35 AM
Guest
Drywall compound is going to shrink too much for woodwork, if you are going to use oil based paint (or primer) use painters putty and stiffen it a little with whiting (paint store), if you are going to use a latex paint then painters putty will bleed through unless primed with an oil based primer, you can use shrink free spackeling, being sure to sand it with a 220 grit after dry, prior to priming or painting.
