Brushed suede painting
I have purchased Brushed Suede Paint (Valspar Corp) and preceeded to paint as instructed. I painted a base coat and then using x's (large and small) tried to make a suede apprearance. It now looks like large and small x's.
Should the x's all be blended together or should spaces be left between as per the directions?
Does anyone know where I can obtain additional info (including pictures) to get the correct effect?
They're not really Xs your supposed to make. Painting up and down in diagonal strokes, both small and large, is more the technique. You need to be very delicate and don't have too much paint on your brush. I also found that overlapping the diagonal strokes makes them look very suede like.
Gini and Rubyroo
Thanks for the information Rubyroo. I will try the overlapping diagonals and not leave as much base showing. Will try using less paint since directions said to fill the brush.
Gini - the color is blue. The base looks darker than when I do the x pattern even though it is the same paint.
I am using a 4 inch color wash brush for the large x's and the side of it for the small ones.
X's are the ticket! Just like the instructions say, load the paint brush and apply a second coat of paint in an x-fashion. Yes, unfortunately I did say a second coat of paint. The X's make a pattern that is not uniform, and the type of paint give the brushed suede appearance. It is very time consuming but really looks great when it's done.
Abby, Good advice all around in this thread! Something about these suedes is each color depth reacts differently to the X's and how much they should or should not overlap. In genearal, most should overlap a great deal. I don't know if this makes any sense but the "pattern" must be randomly inconsistant. No, that doesn't make any sense.....If you are doing X's that don't lap a great deal into the previous X's you probably have a bunch of X's on a base coat. Work on a small wall and back off after its dry and take a look. If it looks like X's lap them over more. Keep a wet edge at all times and remember, each one of these is unique and that is the beauty.....Mike
