images??
Old 02-26-01, 10:01 AM
T
Sorry for being off topic,but i have never seen images posted here.....Do you allow the posting of images or not??
Old 02-26-01, 11:19 AM
mikejmerritt
toptosher, Give this a try...
Adding Images
To add a graphic within your message, just encase the URL of the graphic image as shown in the following example.
http://www.vbulletin.com/images/vblogo.gif
The above graphic is created by adding img within [] before the link and /img within [] after the link. If I had not removed the bracketed code the image would have appeared twice.
In the example above, the vB Code automatically makes the graphic visible in your message. Note: the "http://" part of the URL is REQUIRED for the [img] code. Also note: some forums may disable the [img] tag support to prevent objectionable images from being viewed. In that case, you will have to include a hyperlink to the image.
[Edited by mikejmerritt on 02-26-01 at 02:31]
Old 02-26-01, 11:41 AM
T
Thanks...I know how to do that stuff but i wasnt sure if you allowed it...due to loading times etc. Im glad you do allow us to post pics now and again coz pictures sometimes explain things clearer than words..Thanks again.
Old 02-26-01, 03:35 PM
mikejmerritt
I figured you knew how because you only asked could you but while on the subject I thought some others might see how easy it is to use the code....Mike
