Should I prime a painted wall before spray texture?
I want to spray a light texture onto a painted wall surface. It's dry wall that was painted with what appears to be a satin-finish then papered. We've removed the old paper and cleaned but the painted surface is fairly smooth. Should I prime this wall before having the texture applied? I'll then prime and paint the newly textured wall. Thanks.
Hi Mark,
Thank you for the prompt reply to my inquiry! I thought your idea might be the solution so gave it a try last evening but even after cleaning with TSP and then scuffing it with sand paper the painted surface still feels pretty smooth in general. As this is an area that I can't take a chance on having to re-do I'm still concerned. A recommendation I received at the paint store (naturally) was to put on an oil-based primer for certainty of adhesion. Does this sound reasonable? Thanks again.
Is the existing paint oil base or latex? .. http://www.doityourself.com/forum/pa...latex-oil.html
If there is any wallpaper residue left on the walls they should be sealed with either an oil base primer or Zinnser's Gardz. Sanding leaves minute scratches on the substrate which promotes adhesion even though it doesn't look rough. TSP must be rinsed well! it's residue can cause adhesion issues, I only use it on the exterior.
I'm pretty sure it's latex but it has been over 20 years so will do the tests you recommend. I know what you mean about TSP, very slippery stuff, so have been rinsing and wiping thoroughly.
Thanks!
Thanks!
