How to handle an exterior metal spiral stair painting...
Old 04-11-14, 12:55 PM
C
Hello,
Got a spiral stair on backyard . Painted last year with water base paint , after I removed most of the rust and insulated with a clear antirust coat.
A year later the metal stair has a lot of rusted spots and i'm ready to painted again.
This time I thought to take advices from you guys on what paint to use ( water or oil base) and how to remove the rust, should I remove(strip) the old paint, what is the best rustprove primer...... ????
Thank you
Old 04-11-14, 01:03 PM
Received 753 Upvotes on 658 Posts
Solvent based coatings will inhibit rust a lot better than latex or waterbased. It's always best to remove all the rust [shiny metal if feasible] Latex coatings hold up better in the intense fla sun but have very little rust inhibiting properties.
I would aggressively sand it, remove the dust and coat with a good rust inhibitive oil base primer followed by a coat of oil base exterior enamel. If you are concerned that the oil finish will fade too much you could apply 2 good coats of primer and then a waterbased finish.
Old 04-11-14, 04:02 PM
C
Please any brand suggestion from HD or Lowes on:
- rust inhibitive oil base primer
- oil base exterior enamel
Thanks
Old 04-12-14, 05:15 AM
I rarely buy coatings at the big box stores. Rustoleum has decent primer, I don't know how well their enamels hold up in the fla sun.
Old 04-12-14, 05:21 AM
If you're able to properly clean all the rust, you won't need a rust inhibiting primer
As for finish, devflex seems okay in the weather here in Canada.
Old 04-13-14, 10:10 AM
C
Thanks guys for your advices, one more thing I have to ask/clear, is that I'm not talking only for the rails, the steps need the same treatments as well??
Can I use the same finish oil base paint, or there are products that handle better stepping on ???
Thanks
Old 04-13-14, 11:09 AM
Are the treads metal? A porch and deck enamel might be a little more durable on the treads than regular oil enamel. How much traffic do the stairs see?
Old 04-13-14, 12:21 PM
What about an alkyd floor paint?
I can't really think of anything that would stand up well.... Look at all the metal staircases you've been on, lol. It always wears through in no time.
Old 04-13-14, 01:00 PM
C
Yes, they are metal. The traffic is light....average use... one time per day.
Old 04-14-14, 03:14 AM
Not all floor enamels are for exterior use. Alkyld [oil base] will wear better than waterbased coatings. The paint will wear off of the treads over time but IMO it isn't a big deal to recoat just the treads when the wear becomes excessive.
Old 04-14-14, 10:52 AM
Pre-catalyzed epoxy? Sherwin Williams has one that's not too pricey. Used it in a university lab a couple years ago. 2 coats on block and it dried ridiculously hard, though not as good as a real epoxy.
