Painting paneling
I HAVE BEEN TOLD A WATER BASED PRIMER AND A WATER BASED PAINT APPLIED WITH A GOOD ROLLER IS BEST FOR THIS. I HAVE READ HERE THAT A LATEX IS RECOMMENDED. WHICH IS TRUE?
PAUL T.
PAUL T.
Latex paint is water based. You can use a water based primer such as Kilz Total One or Zinnser's 1-2-3. They do have good bonding qualities, you will need to clean and lightly sand the paneling with a 220 grit paper prior to priming for adhesion. For a better bond use an oil based primer such as Kilz Original prior to painting.
Hope this helps.
Hope this helps.
