How to paint 'Chimney' on the rooftop successfully?
Old 05-19-14, 09:57 PM
PineCone's Avatar
Hello:
I recall we painted 'chimney' on the rooftop about 4-5 years ago by using top-rated oil paint with good quality primer. Now, half of the chimney painted started peeling off and needed to re-paint it so badly.
Any idea about 'how to paint 'chimney' on the rooftop at least it lasts more than five years?
Thanks for any help on this, in advance
Old 05-20-14, 03:51 AM
Received 759 Upvotes on 664 Posts
You need to provide a better description of the chimney, mainly how it's built - pics would be nice.
Is this a wood 'chase' type chimney? masonry? or just a stack?
Old 05-20-14, 05:12 AM
PineCone's Avatar
It's made of a kind of 'galvanized' type Chimney. At least, I can say that it's old-fashined Chimeny which we can see in '50 - 60's houses.
I want to take a picture of Chimney, but it's hard to take a phote which needed to climb up all way top of rooftop.
Please tell me more information if I need to provide to resolve the issue.
Thanks,
Old 05-20-14, 05:18 AM
So it's basically stove pipe. That's probably the hardest thing to get a long lasting paint job on Latex paint tends to adhere longer to galvanized than oil base does because it is somewhat flexible where oil base coatings are not BUT latex has no rust inhibitive qualities and might melt depending on how hot the pipe gets.
IMO a paint job that lasts 4-5 yrs on galvanized stove pipe is about as good as it gets.
Old 05-21-14, 04:26 PM
Devoe makes a "direct-to-metal" alkyd based paint. Seriously awesome provided you do the right prep.
