Touch-up Paint Too Dark
Old 08-12-14, 04:59 PM
G
I just filled some holes and painted over the spackle. My walls were painted 10 years ago and still look great except for these repairs and one or two other spots. I bought the same color of Sherwin Williams paint, and it's just a little too dark. These holes are in a stairwell, and the walls are 2 stores high. I do not want to paint the entire wall! Ugh!! Is there anything I can do?? Can I have the paint lightened just a bit?
Old 08-12-14, 05:26 PM
You definitely can have it lightened. Even if you had bought two separate gallons of paint the same day, let alone, 10 years apart, you can have those same variances. But it's going to be pretty difficult to match it exactly, sad to say. And I feel you on those high walls, my Aunt had my brother and I doing some crazy paint technique on her insane foyer.
Old 08-12-14, 05:32 PM
Norm201's Avatar
Received 594 Votes on 531 Posts
If you can provide a 1 sq inch of paint sample the local hardware can color match and mix up a quart of paint. Most mixed paints will give warning that they will fade in direct sunlight or after extended periods of time.
Lightening or darkening already mixed paint is not so easy. Adding white or black does not necessarily lighten or darken a mixed paint. That's why the color match computer is used against a sample. When I mix paint for a customer, I'm amazed at the formula to achieve different colors. Not what seems intuitive. For many colors I start with a gallon of white (and not a base), then I may need to add several ounces or parts of an ounce to the already white paint.
Old 08-13-14, 03:12 AM
Received 680 Votes on 601 Posts
Short of having a painter experienced at color matching on site - I wouldn't expect to be able to get a good touch up on a 10 yr old paint job! Paint color is only part of the equation, sheen, coverage and how that section of wall reflects light all play a part in how successful a paint touch up will be.
Over the last 20 yrs or so, paint stores have gotten a lot better at making colors consistent. The computer tint machines are recalibrated on a regular basis but paint formulas [not tint] change over the years both to meet new gov't regs and improvements in the coating.
