Ryobi paint sprayer problem
Old 10-06-14, 02:06 PM
F
Hi All,
I got a used paint sprayer RAP200. When I got it the guy turned it on and seemed to be ok. I tried it now but it trips the GFCI outlet every time (tried different outlets). The first time I tried it lasted a few seconds but now not even a second. I am thinking it is a pressure problem but I have it set to "prime", so I believe no pressure is built.
I never used a paint sprayer like this one, so I am not sure what could be wrong
Has anybody had a similar problem? What can ?I try to fix it (if fixable)
Thanks in advance
Old 10-06-14, 02:24 PM
Received 757 Upvotes on 662 Posts
Are you trying to pump anything thru it? or just turning it on empty - they need paint or thinner for a lubricant.
Old 10-06-14, 02:33 PM
F
I am testing it with water for now. Do I need to use paint for testing ?
Old 10-06-14, 02:34 PM
No, water is fine. Have you tried it on a non GFI outlet?
