Help with painting bathroom fixtures
Hi everyone,
I am new to the site and hope you can help. I wanted to paint my brass bathroom fixtures to satin nickel. I started with the bath tub. I sanded the spout and handles very well with 220 grit sand paper. I then taped very well and applied a metal primer. I applied several coats of the primer and waited 24 hours. This morning, I sprayed with satin nickel. Waited several hours only to find that I can rub everything off with my fingernail. I used Rustoleum products. What did I do wrong? It looks great until, but clearly is not functional.
Thank you so much for any help,
Kay
Kay
Your house and therefore your call but I would buy new fixtures or live with what you have (I know, too late for that now); I would never attempt to paint plumbing fixtures.
I'm concerned about the mention of multiple coats of primer - how much time did you give between coats and how many total coats? Normally one coat of primer is all that's required but multiple coats of paint is often needed.
I still stand by my recommendation to buy new but we can try to troubleshoot this if you're adamant about not buying new.
Hopefully she'll see your post and reply but it is very difficult to get a long lasting paint job on plumbing fixtures. 1st the faucet's factory plating doesn't promote good adhesion and 2nd the type of wear the faucet would receive makes it hard for a paint job to last.
