Painting over wood cabinets and shelving
I'm going to paint over old, dark blue, cabinets.
My thoughts:
- Remove all doors and hardware from doors (mark and map door locations)
- Remove all (removable) shelves (mark and map shelves)
- Wipe down all paintable surfaces
- Prime all surfaces with Zinnser primer
- Sand all surfaces with 220 grit sandpaper
- Roll all flat faces and inside of cabinets
- Brush all doors
I was thinking of using Benjamin Moore Satin Impervo (White)
Anyone have any better ideas or thoughts on this process? I don't have much experience painting hardwood.
My thoughts:
- Brush all doors
I generally number the doors with a magic marker behind the hinge, the drawers can be marked on the backside or bottom. It's always a good idea to sand lightly before applying the primer. I like to wipe/wash the doors with a liquid deglosser [after sanding] as it removes any wax [sanding dust too] and softens the existing finish for a little while promoting better adhesion.
Which Zinnser primer do you intend to use? I don't use BM coatings all that often but assume Impervo comes in oil base, latex and waterborne - which do you intend to use? While oil base dries to the hardest film - whites will yellow with time. Waterborne dries almost as hard as oil but doesn't yellow and dries quickly.
You might find this helpful - http://www.doityourself.com/forum/pa...t-repaint.html
Do you know what type of paint is currently on the cabinets? http://www.doityourself.com/forum/pa...latex-oil.html
