What is the "Penetrol" / "x-tender" / "floetrol" of acrylic two part epoxy?
Old 03-08-15, 01:58 PM
thinking of using acrylic two-part epoxy paint -- "tub and tile" paint from rustoleum. What product can be used to extend the drying time for better flow and self-leveling? Since it is labeled as "acrylic epoxy", can x-tender be use?
Old 03-08-15, 03:00 PM
Received 1 Upvote on 1 Post
Really big mistake.
Have a pro come in and and refinish it if you want a long lasting finish.
Tried it total disaster, failed in two years.
Old 03-08-15, 08:15 PM
Haha. Thanks for the reply. I am actually not planning to use it inside a tub or shower (long story). What is the proper extender, then?
Old 03-09-15, 03:19 AM
Received 758 Upvotes on 663 Posts
Exactly what will you be painting?
Flood's Penetrol is only for oil base coatings, their Floetrol is for latex. XIM's Xtends is also for latex. While I've used these additives, I've never used them with an epoxy. It would be best to contact the paint manufacture and see what they recommend. Often a little thinner [as noted on the can] along with careful application is all that is needed to eliminate or reduce brush marks or roller stipple.
Old 03-09-15, 05:58 AM
XSleeper's Avatar
Received 1,748 Upvotes on 1,572 Posts
The mfg. will surely tell you not to thin as it will surely void the warranty, unpredictably affect adhesion and sagging, etc. Epoxy dries chemically, so anything you add could screw with that recipe.
That being said, I am sure that adding a bit of Xylol (already one of the components) would thin it slightly more for the self levelling, but its hard to predict how that would affect the thickness of the coat or the dry time.
I would DEFINITELY not use any of the products you mentioned in an epoxy.
