Painting over decals/stickers
Old 04-23-15, 09:15 PM
B
The previous owner of my house decided that covering the garage walls with various large decals was a good look. I tried peeling them off, but the only one that would budge took the underlying paint and drywall paper with it. I'd like to just paint over these things.
I bought and used a spray can of Sherwin Williams bonding primer. What's my best bet from here? Do I need to use a latex or oil based primer, specifically?
Old 04-23-15, 09:19 PM
Received 3,485 Upvotes on 3,128 Posts
Any paint will cover them but you'll always see that it was a decal as it will have a raised surface.
Did you try heating them with a blow dryer for removal ?
Old 04-24-15, 03:43 AM
Received 755 Upvotes on 660 Posts
Since you've already primed over the decals it will be a lot harder to remove them. At this point I'd spread a thin layer of joint compound over/around the decal, sand when dry and texture if needed.
Old 04-24-15, 05:44 AM
B
Thanks, guys.
The bonding primer spray that I used just lightly dusted the decals. I think I still need to prime them again, as well as the rest of the darker colored walls. Being an aerosol, I assume the bonding primer is oil based. Does this mean that I need to used an oil based primer, or can I use latex?
Old 04-24-15, 06:44 AM
You should be able to use any latex primer or paint over oil base primer [shellac based too]
