Painting over dark walls with a similar dark color
Old 05-28-15, 12:19 PM
A
Hello,
I'm going to be moving into a new residence soon and it has dark blue and medium brown walls. I'd like to repaint the walls with similar colors, just to give them a fresh coat, and was wondering if anyone can provide any advice or tips on how to repaint dark walls with another dark color.
Thanks.
Old 05-28-15, 01:29 PM
Received 759 Upvotes on 664 Posts
Welcome to the forums!
I'm not sure I understand the question You'd apply the dark paint just like you would any other although roller marks and such aren't as forgiving as a lighter color.
Old 05-29-15, 01:40 PM
D
Received 5 Upvotes on 5 Posts
Many paints now are a primer-and-paint-in-one product. I'm inclined to think applying a separate primer is a better approach but I honestly haven't had much experience yet with the new primer-and-paint-in-one products. Using such a product might be fine in your situation and save some labor. If you do apply a separate primer, I would certainly ask the paint store to tint the primer to, or nearly to, the color of the paint you will be using. Obviously, you'll get better coverage with your topcoat by doing this.
Old 05-29-15, 01:41 PM
Normally repaints don't require a primer. IMO the primer in the paint is more of a marketing ploy than anything else.
Old 05-29-15, 01:44 PM
P
Temporarily Suspended
I agree with marksr. Just roll the paint like any other paint.
Question. Doesn't arugula make your pizza bitter?
Old 05-29-15, 01:53 PM
D
My recent visits to Home Depot and Lowe's indicates the majority of paints now are the primer-and-paint-in-one products. I agree this may be more of a marketing ploy than a true enhancement to paints.
If painting over glossy or semi-glossy paint, some sanding should be done to improve adhesion of the new topcoat. I believe this advice is usually stated on the instructions on the paint cans.
Old 05-29-15, 01:57 PM
Sanding should be part of the paint prep anyway .... I do it without thinking and sometimes forget to mention it The more sheen the existing paint has the more important it is to sand!
